BillyG wrote:Check them all. Every last one.
lil bean wrote:Get the tools out and start where??? bike/sidecar
Eveyone?
Ragman wrote:If you want somewhere to start at first - deal with everything related to the wheels, then the hack, then the frame, then the rest - literally every fastener on the rig needs to be checked often. That includes all electrical connections, and fuel connections. Check the tire pressure every day, as it is going to go down every day. The hotter it is, the more the tubes leak.
markhas wrote:Ragman wrote:If you want somewhere to start at first - deal with everything related to the wheels, then the hack, then the frame, then the rest - literally every fastener on the rig needs to be checked often. That includes all electrical connections, and fuel connections. Check the tire pressure every day, as it is going to go down every day. The hotter it is, the more the tubes leak.
I've had very little problem with tubes leaking. I been able to get every new tyre to settle in and stop leaking if it was a problem at all, a couple were but for the most part I don't leak a lot of air. Ahh heemmmm ah not from my tyres anyway...
lil bean wrote:markhas wrote:Ragman wrote:If you want somewhere to start at first - deal with everything related to the wheels, then the hack, then the frame, then the rest - literally every fastener on the rig needs to be checked often. That includes all electrical connections, and fuel connections. Check the tire pressure every day, as it is going to go down every day. The hotter it is, the more the tubes leak.
I've had to zip-tie a fuel line for now...will get to work on bike today. Tire pressure...read in the Manuel: Front 32 psi Side 30 psi Rear 40 psi, Is this what you all run with? O ya isn't it lefty loosey righty tighty
Return to Ural/Dnepr 101 - Newbie Questions
