Parking Brake screw
Are you new to Urals & Dneprs, or thinking about getting one, and have questions? Ask your newbie questions here.
Here's the place for those who are new owners or thinking about buying a Ural or Dnepr to ask those typical "newbie" questions. Try using the "Search" link at the top of the page to see if your question may have been asked before.
Parking Brake screw
Postby MartyL » Sun Apr 20, 2008 11:50 am
While I was riding the other day. I stopped for lunch. Where I parked I was on a slight hill (Can you believe a hill in Florida). I thought I'd use my parking brake which I never use because I usually forget to release it when I take off. I usually just leave it in reverse. Well....... When I went to engage the parking brake I noticed that the screw that is attrached to the parking brake which holds the foot brake down was missing. My question.... Could someone look at the parking brake and describe to me what kind of screw I need to replace it? I remember it had a nut on it as well. Thanks.....
MartyL
Postby lil bean » Sun Apr 20, 2008 6:47 pm
I'm not the best person to answer this but here goes...I opened my tool kit that came with the Gear-Up and a size 10 open face wrench fit on the head of the bolt you lost and size 10 wrench fit on the nut also. The bolt maybe about 1'' long and less than 1/4'' wide...not sure if this half a$$ answer will help. Good-Luck
M6-1 by 30 mm long...ya that's what I was thinkin :lol:
2007 Ural Gear-Up 2WD Desert Camo
"Life is not measured by the breath you take but by the moments that take your breath away"
Not Used...Broken In
lil bean
Postby George Butz » Sun Apr 20, 2008 6:52 pm
You need an M6-1 by 30mm long bolt, Marty. :wink: with a nut..
2007 Patrol (slightly modified, heh heh...)
1988 Airhead GS
George Butz
Postby lil bean » Sun Apr 20, 2008 7:17 pm
Thanks for fixin my silly post...(in. don't work here) mm only :oops:
lil bean
Postby Yankee Dog » Mon Apr 21, 2008 8:23 am
[quote="George Butz"]You need an M6-1 by 30mm long bolt, Marty. :wink: with a nut..[/quote]
And maybe a little Loctite
yankee Dog
Yankee Dog
Postby JohnBG » Mon Apr 21, 2008 1:01 pm
Yankee Dog wrote:
George Butz wrote:You need an M6-1 by 30mm long bolt, Marty. :wink: with a nut..
yankee Dog
No loctite!
Use a bolt with a nut. Once you have the bolt postioned to keep enough parking lever tesion to stop the bike from moving, use the nut to tighten the bolt againt the brake lever and secure it.
Periodically you need to adjust that nut in betwen adjustments of the rear and sidecar brakes.
John Grocke aka "JohnBG"
'06 Ural Raven - "Vorona"
JohnBG
General Secretary
General Secretary
Postby Ragman » Mon Apr 21, 2008 3:37 pm
For some strange reason, my parking brake has never worked. It doesn't get anywhere near the stop..
Милаж
Uralist & Bulleteer
2005 Ural Tourist - Black - converted to 2wd (sold)
1999 Royal Enfield - Green - Classic (sold)
2002 Yamaha TW200 - White, with Blue (sold)
Ragman
Postby JohnBG » Mon Apr 21, 2008 3:37 pm
Ragman wrote:For some strange reason, my parking brake has never worked. It doesn't get anywhere near the stop..
Well then adjust the screw or adjust the brake silly... :P
JohnBG
General Secretary
General Secretary
Re: Parking Brake screw
Postby millers1 » Mon Apr 21, 2008 4:03 pm
MartyL wrote:While I was riding the other day. I stopped for lunch. Where I parked I was on a slight hill (Can you believe a hill in Florida). I thought I'd use my parking brake which I never use because I usually forget to release it when I take off. I usually just leave it in reverse. Well....... When I went to engage the parking brake I noticed that the screw that is attrached to the parking brake which holds the foot brake down was missing. My question.... Could someone look at the parking brake and describe to me what kind of screw I need to replace it? I remember it had a nut on it as well. Thanks.....
The screw on our '05 Patrol dissapeared a while back, too. Metric capscrew the size someone already mentioned. Lock nut. Blue Locktite. If you still need a digital drop me a PM.
'05 Ural Patrol - sold
'98 HD Electra Glide
'00 Road Star
millers1
Postby Ragman » Mon Apr 21, 2008 5:27 pm
I tried both of those things, and still, it did not reach the stop.. I suspect it has something to do with the fact that my rig has a mind of it's own. Either that, or Ivan made it wrong.
Милаж
Uralist & Bulleteer
Ragman
Postby JohnBG » Mon Apr 21, 2008 6:53 pm
Get a longer bolt... :wink:
JohnBG
General Secretary
General Secretary
Postby greenmachine » Mon Apr 21, 2008 7:35 pm
Ya know....
My parking brake lever works OK, but for some reason folks will apparently " fiddle " with it whilst yer in some joint having a cup o' joe ... and yer bike will be free to attempt to limp towards lower ground one gear tooth at a time.
I only use the parking brake maybe a few times a year it seems, only when I'm on quite steep terrain. I've given up with trusting the parking brake though, and if the possibility is apparent that the rig will not hold on the gearbox then I pull a bungee through the U-joint and hooked to each side of the frame. This will hold the rig on any slope no matter what... BUT ..... one does NOT want to forget when one has done such a deed and attempt to ride off with the bungee still attached ....
I'm just sayin...
kermitski
Russian biker has-been....
Rode around the block a couple times
and got rid of the goofy thing...
greenmachine
Return to Ural/Dnepr 101 - Newbie Questions
