MartyL wrote:You have just described my senerio as far as kick starting. Just so you know, it's a good idea to pump the kick starter a couple of times before you engage the electric starter. This will prevent a possible vapor lock issue if fuel gets into the heads (Petcock left in prime with engine off..... Very Bad). Most times I can get her started on the first kick after I do two priming kicks/pumps. If she doesn't fire right off, personally I get lazy and hit the electric and she fires right up. I have the stock jets on my bike so when cold with enrichers on only for maybe 30 sec. Then I shut off enrichers and slightly crack the throttle till she can hold idle by herself. Outside temps around in the 60's to 70's most these days. (I'm a Florida boy you know.)
If not for reading about this, here, I'm sure disaster would have followed if I had pushed that button. It pays to read all those H&W'n posts when you first get one of these beasts.
It has to be 45 or cooler before the enrichers work for me on a kick start
