I figgered
Cost about $7.00. When I picked up my rig, the signal indicator on the dash was not working. I figgered to have it fixed t the first service no biggie. I plug in the new flasher and shazam, indicator light works. Go figger.
Bilgekeeldave wrote:My Ukrainian flasher works fine after four years!
Dave
Big Yellow wrote:Yup, no doubt about it I need a wiring diagram.
Anybody have one?
Symptom is, just the left front flasher fails. Not the bulb, not the flasher unit (both have been replaced). There is a dead short in the yellow line going to the left front signal (but remember, all the others work). If I open the connector behind the headlight the short is on the harness side of the connector.
So just where does that line go?
I don't want to take the bike compleatly apart if I don't need to
Help
Big Yellow wrote:.....................Symptom is, just the left front flasher fails. Not the bulb, not the flasher unit (both have been replaced). There is a dead short in the yellow line going to the left front signal (but remember, all the others work). If I open the connector behind the headlight the short is on the harness side of the connector.
Help
