Most of you are already aware of a fine product made by Jim at "Raceway" his tank shifter that will shift the forward gears and reverse. I have been bugging Jim for over two years to make a shifter that will shift the two wheel drive instead of the forward gears. My wishes have been answered.
I just had the "CC" checked out by Sergey after it's abuse in Death Valley, while there we installed this new shifter that Jim made, there were no installation instructions but none were needed it's a very easy to install system. It does take a bit of tinkering with the adjustments to get everything to shift smoothly but nothing the average Ural pilot is not capable of.
I have had the shifter on the rig now for about a week, it works VERY well and is super smooth in it's operation. The shift into and out of two wheel drive is easy and fast this is very important when riding off road where you want to be able to get into and out of two wheel drive while on the move and in a hurry.
I have not yet been able to test how this works in very rough terrain but I do not anticipate any problems. The materials this shifter is made from and the workmanship is top notch as are all of the products that come from Jim's shop. I highly recommend this shifter. I do not know if Jim has these for sale or if this is the only one that was made for test purposes. Contact Jim for price and availability, tell him "Cob" sent you.
Contact Raceway here.
2700 19th St SE Unit#3, Salem, OR 97302
Phone: (503) 588-7227
Fax: (503) 363-6952
racewayservices@cs.com
www.racewayservices.com
Here is the shifter.
The rear bell-crank assembly.
Reverse.
Two wheel drive.
