First Service To-Do List
Postby St0nkingByte » Mon Feb 25, 2008 6:32 pm
With all this amazing weather we're having here in WA it looks like this coming Saturday is going to be set aside for me to do the first service on the Ural. This morning I was looking at the manaul to see what will need doing and I'm thinking the list from the service coupon page might be missing a few things.
Here's what the service coupon page says to do:
  • Change engine oil and filter.
  • Change transmission oil.
  • Change final drive oil.
  • Check condition of the gasoline petcock, remove any contaminants, replace in-line fuel ilters.
  • Check carburetors while idling for synchronous operation.
  • Check tension of wheel spokes.
  • Check fasteners for proper tightening.
  • Check steering column bearings.
  • Check alternator bolts
  • Check brake fluid reservoir
I'm thinking this list also needs:
  • Torque the head bolts
  • Adjust valves
  • Check/torque sidecar mounts
  • Check/adjust brakes
What else am I missing?
2007 Patrol
St0nkingByte
Postby JohnBG » Mon Feb 25, 2008 9:27 pm
That's pretty much it...
I don't torque the heads past 36 ft-lb, even though the manual sasys 40-42 IIRC.
If ya got one of them Ducati ignitions on yer new rig, you could alsways drag out the timing light and check it, but probably not necessary.
John Grocke aka "JohnBG"
'06 Ural Raven - "Vorona"
JohnBG
General Secretary
General Secretary
Re: First Service To-Do List
Postby WKinNJ » Mon Feb 25, 2008 9:29 pm
St0nkingByte wrote:With all this amazing weather we're having here in WA it looks like this coming Saturday is going to be set aside for me to do the first service on the Ural. This morning I was looking at the manaul to see what will need doing and I'm thinking the list from the service coupon page might be missing a few things.
  • Adjust valves
Even though the manual said nothing about checking head torque or adjusting the valves on the first service, on some good advice I did this anyway. Turns out it the heads and the valves really needed to be done. I also “Checked fasteners for proper tightening." Good thing, the battery cable was ready to fall off.
WKinNJ
Postby S 854 » Mon Feb 25, 2008 9:31 pm
Thanks for the post, Stonk...
I've been thinking about this topic for awhile... might I add to you list...
Is it a good idea to have the first service done by a Ural shop, if possible...?
Time's gonna be kinda tight this June, and if I don't have to spend a couple-three days riding in circles to get up to the 500 klic mark, I'd be three days ahead... if ya know what I mean...
Postby JohnBG » Mon Feb 25, 2008 9:33 pm
S 854 wrote:Thanks for the post, Stonk...
Most Ural dealers include the first 500km service. At least mine did... 8)
JohnBG
General Secretary
General Secretary
Postby St0nkingByte » Tue Feb 26, 2008 3:06 am
My dealer is a good 120 miles away so I'm going to do my own. I can do all the service on my 2005 BMW so I'm thinking the Ural is going to be super easy.
The mech at my dealer suggested 38 lb-pounds for the head bolts, I think. Or maybe he said everywhere the manual said 40-42 use 38 so you don't break anything ;). Something like that.
2007 Patrol
St0nkingByte
Postby Spyder » Tue Feb 26, 2008 9:33 am
I took mine to a service shop for the 500; I wanted someone who knew what they were doing since it's the first one and all. I clustered through the second one myself :lol:
On the 7th Day, God rested. Marines filled sandbags! Image
Spyder
'07 Gear-up - "War Pig"
"Yea I say unto you, my Brothers, beware those who encourage the overzealous cleaning of your [Ural] for they are the devil incarnate..." - Mr. Cob
Spyder
Postby George Butz » Tue Feb 26, 2008 1:30 pm
Looking in my 2007 manual, the adjusting of valves and re-torque is scheduled for the 10,000 km service. No problem checking this earlier, but that is what the manual requires. Maybe tighter tolerances and aluminum cylinders make a difference from the older schedule. :? Mr. Glaser will probably shed some light on this, as I am rather curious about it, myself. :oops:
2007 Patrol (slightly modified, heh heh...)
1988 Airhead GS
George Butz
Postby St0nkingByte » Tue Feb 26, 2008 11:35 pm
George Butz wrote:Looking in my 2007 manual, the adjusting of valves and re-torque is scheduled for the 10,000 km service. No problem checking this earlier, but that is what the manual requires. Maybe tighter tolerances and aluminum cylinders make a difference from the older schedule. :? Mr. Glaser will probably shed some light on this, as I am rather curious about it, myself. :oops:
Oh don't tempt me, skipping the valve adjust and head bolt torquing would save a bunch of time (Yes I'm slow).
2007 Patrol
St0nkingByte
Postby redflasher » Wed Feb 27, 2008 8:48 am
I did my valves at 1000 km and they all needed adjustment. Seemed a little quieter afterward. But now, the left valve cover seeps a bit. No big deal.
Bob in Minnesota
2006 GearUP
'Friends come and go. Enemies accumulate.'
'Whilst sidecaring definitely builds both character and muscles, it's not as difficult as some people claim'
redflasher
Postby heindlengineeringural » Fri Feb 29, 2008 12:04 pm
We always check the valves at the 500km service. Sometimes they do need ajusting at that point. When we do a setup on a new machine we also check the valves before the engine is ever started at our shop. A lot of times, the valves are set a little too tight from the factory. As Sergey says...loose good...
Heindl Engineering, LLC
Ural Dealer in Southwest Ohio
(937) 787-3686
www.heindlengineering.com
sales@heindlengineering.com
1st service to do list
Postby URAL CT » Fri Feb 29, 2008 1:35 pm
Hi ya'll,
What should the intake and exhaust valve setting be? OK head torque not to exceed ~36 ft-lb.... cool.
Thanks.... 8)
CT
2007 Patrol
URAL CT
Re: 1st service to do list
Postby berger » Fri Feb 29, 2008 1:46 pm
URAL CT wrote:Hi ya'll,
Thanks.... 8)
The manual recommends .004, but I believe Mr. Cob and others sets theirs at .005. Anywhere between those two is good. Remember, you should be able to release the gauge and have it stay there when you do your adjustment. Three hands is ideal, but once you get used to it, you can do it with the two God gave ya. :D
berger
Berger
2007 Patrol
Modtop Exhaust/Airbox
145/45 Jets
Drilled Carb slides
2 M3 washers shims
berger
Postby URAL CT » Fri Feb 29, 2008 4:24 pm
Hi Berger......is it .005" for intake and .005" for exhaust :puzzled: ??? Oooops sorry st0n .. I didn't mean to hijack this thread. :(
Charlie T. 8)
CT
2007 Patrol
URAL CT
Postby ReCycled » Fri Feb 29, 2008 5:53 pm
Read down to post # 62 of this thread and you'll see Mr. Cob is happy with .006" intake and exhaust.
http://www.advrider.com/forums/showthre ... light=.006
David B.
Now: '07 Tourist
'79 XS650, '92 K75
Then: '02 Tourist, '04 Patrol, '?? MT16
CB350four, XS650, R65, XLH, FXEF
Next: ????????
ReCycled
Next
