trouble getting into neutral
Postby mightymatt43 » Fri Feb 15, 2008 6:58 pm
i have a new 2007 gear up with 200 km (yes, brand spankin new). i've been having trouble finding neutral because the indicator light does not come on unless i put pressure on the reverse shifter. i'm having trouble finding it regardless but without the indicator light it makes it even more difficult. i've tried tightening up things where i could (pictured below) but alas i'm still having the same problems.
any ideas?
mightymatt43
Postby BillyG » Fri Feb 15, 2008 7:14 pm
In the beginning when the g.b. is new and tight, reverse can be a little difficult to slip into. I found (in the beginning) it was easier to grasp the lever with my hand (palm on lever knob) and using a "stiff arm", pop the lever back using a little body weight. You can "feel" what is going on better than if you are using your boot.
There is actually two detents/notches to the neutral/reverse lever; the first will get you into neutral, the second into reverse. If you are aiming for neutral it really does not matter which you get into...just remember to move the neutral/reverse lever fully forward to stay in neutral. Some g.b.'s if the lever is just slightly aft a hair...you can not engage any gear. Usually happens at a traffic light and you'll think your g.b. just went out.
Later, after you get the feel for it, and the g.b. loosens up a bit...you can easily use your right heel on the lever to bump it into neutral or reverse. Once the g.b. is well worn (10,000 Km's or so) it will just about drop into reverse with little effort.
The adjustment for the neutral lamp is the nut/screw/wire just ahead of the lever in your picture above. Loosen the outer lock-nut while holding the screw steady with a screwdriver. Back the screw out 1/2 a turn or slightly more. Turn the ignition "ON", put the g.b. in neutral and slowly (very slowly) turn the screw in (CW) until the lamp illuminates. Slowly depress the shift pedal to see if the lamp flickers...you should continue adjust the screw until the lamp does not flicker or go out until you are starting to feel pressure (or slightly before) on the shift pedal BEFORE going into 1st gear. When happy, tighten lock-nut whilst holding screw steady. Does not need to be gorilla tight, just snug. BE CAREFUL AS IF YOU SCREW THE ADJUSTMENT SCREW IN TOO FAR IT WILL NOT ALLOW YOU TO SHIFT THE G.B. AND CAN SHEAR THE ADJUSTMENT SCREW OFF. You have been warned. It is not as scary as it sounds.
If you are curious as to how all the bits and pieces work together in the g.b.....go here: http://myural.com/how_the_gearbox_works.htm
Bill Glaser
2002 Ural Patrol "CYKA"
110,000 km's since May 1st 2002
The "Unofficial Ural Service Manual" can be viewed at: www.myural.com
BillyG
Thread Killer
Thread Killer
Postby Latguy » Fri Feb 15, 2008 8:42 pm
When I got my GU in September 07, I rubbed a raw spot on the top of my left foot trying to shift it like my BMW. The dealer (Bill Coffin in Poland, Maine) suggested that I use the heel pedal to upshift and to move the lever firmly. I mentioned that Neutral was very hard to find and he assured me that as the gear box wore in a bit, shifting and finding Neutral would become much easier. With 2700km on the meter, he's right.
While it is possible that something is misadjusted, I think it is very likely that things will loosen up with the miles.
Happy trails!
Thanks - V
'07 Gear Up Desert w/Modtops
'74 R90S w/SuperTrapps
Latguy
Postby QBall » Fri Feb 15, 2008 8:42 pm
A good reverse then back shift always does it for me. I never find N with the shifter
QBall
2007 Gear Up - Yertle
1999 Victory V92C
2000 Triumph TBird
CURD Ambassador to Connecticut
QBall
Postby Spyder » Fri Feb 15, 2008 11:22 pm
Mine has loosened up considerably since it was new, I'm at 3000k now and it's to the point where I normally drop to N from 2nd and the final coast to the stop. I find minor downward pressure to N is easier for me than all the way to 1st, then a tad up to N - dunno why, weight of the foot vs. upward applied force or something, but it works :D
Matt, don't you just friggin' love the smell of your garage after a ride?
"You smell that? Do you smell that? Ural, son. Nothing else in the world smells like that. I love the smell of a Ural after a ride. You know, one time we rode a hill, for twelve hours. When it was all over I walked up. We didn't find one inch of dirt un-touched, not one stinkin' blade of grass. The smell, you know that Ural smell, the whole hill. Smelled like - FUN. Someday I gotta paint these pipes, son."
:lol:
On the 7th Day, God rested. Marines filled sandbags! Image
Spyder
'07 Gear-up - "War Pig"
"Yea I say unto you, my Brothers, beware those who encourage the overzealous cleaning of your [Ural] for they are the devil incarnate..." - Mr. Cob
Spyder
Postby JohnBG » Fri Feb 15, 2008 11:26 pm
Ivan don't surf! :P
John Grocke aka "JohnBG"
'06 Ural Raven - "Vorona"
JohnBG
General Secretary
General Secretary
Postby mightymatt43 » Sat Feb 16, 2008 1:23 pm
Bill - i adjusted the neutral lamp per your instructions and it helped tremendously. thanks for the advise.
spyder - i'm hoping once i break it in a bit it'll loosen up but i will say i've also found it easier to find neutral by moving my toe town rather than up.
and yes, i freaking love that smell. at first, i honestly thought something was wrong but now i'm realizing that's just how the beast smells. i love it. oh, and i may have to steal that "quote" for my sig line - priceless...
mightymatt43
Postby S 854 » Sat Feb 16, 2008 4:34 pm
Spyder wrote:
:lol:
What's this... a scene from "Brokeback Sidecar"?
Postby Spyder » Sun Feb 17, 2008 9:41 am
S 854 wrote:
Spyder wrote:
:lol:
:o
BLASPHEMER!
Spyder
Spyder
Postby catfish » Sun Feb 17, 2008 3:05 pm
Spyder why the uproar?? Wasn't he First Air Cav surely not a Marine??
CATFISH
catfish
Postby Spyder » Sun Feb 17, 2008 8:46 pm
He played one on TV once ("The Great Santini"), but that's about as close as he's gotten to wearing my uniform :lol:
Spyder
Spyder
Postby Mud Pie » Sun Feb 17, 2008 9:03 pm
And for the proper use of the reverse lever:
As I was trained by my dealer, do not, under ANY circumstances, use your hand to shift the reverse lever !!
It's a sure sign of a newbie and it makes the uniqueness of a geared reverse all too obvious.
The proper method is to use the heel of your boot to put it in reverse, then the side of your boot to take it out.
To onlookers, (especially those on 2 wheels) they will gawk in amazement as you pull back, then go forward, with no obvious flicking of levers, etc. :D
2005 Ural Gear Up with DP-28 replica
Patriot Guard Rider
"I don't drive a Ural to make great time, I drive a Ural to have a great time."
"There is no way to rule innocent men. The only power any government has is the power to crack down on criminals. Well, when there aren't enough criminals, one makes them. One declares so many things to be a crime that it becomes impossible for men to live without breaking laws." - Ayn Rand "Atlas Shrugged"
Mud Pie
Postby JohnBG » Sun Feb 17, 2008 10:34 pm
Mud Pie wrote:And for the proper use of the reverse lever:
:bs: I hit the reverse lever with my hand always.
Besides it's hard for me to maneuver the size 12 boot down there. I've tried using my foot but never could get it to work.
JohnBG
General Secretary
General Secretary
Postby Bilgekeeldave » Sun Feb 17, 2008 10:42 pm
I'm usually already down there releasing the parking brake so it's no big deal.
Dave
RAMCO-Dnepr MT-16
Bilgekeeldave
Postby George Butz » Sun Feb 17, 2008 11:13 pm
When I made my reverse lever, I left the stock lever in place. It's fun to kick it with my foot and watch people's faces when the tank lever moves by magic and I back out of a parking spot. People always watch, it seems, to see if I have to push it backwards or have reverse. :P
[with my ankle problems I can push it down, but can't seem to use my foot to move it back into neutral. Ouch :x Bend over to use my hand...double ouch :lol: ]
2007 Patrol (slightly modified, heh heh...)
1988 Airhead GS
George Butz
Next
