Hi everyone,
Today I should roll over 1000 km. I thought I'd give y'all a report...and it'll be short...and that's a good thing.
First, I have an 07 Patrol I picked up in mid September (built in Feburary), drove for two weeks and then spent 2 months in the shop awaiting parts due to an accident. So actual drive time has been about 8 weeks.
The most I've ridden it at one time was 2 forty-five mile runs. The rest have been small commutes every day to work, stores and restaurants (each less than 8 miles).
Maintenance was done as required.
Around 200 Km, the turn signals went out.
At 300 KM, the strap that holds the right passenger foot peg and muffler came loose.
At 900 KM, I raised the shocks and it's a much better ride. Also at this time, I noticed extremely minor seepage around the engine and final drive, to which I tightened the bolts. The seepage is so minor that there are no drips on the garage floor.
And that's it. I am extremely pleased with this machine. I got a chance to ride another persons 06 GU. There's a world of difference here. My rig is much more quiet and doesn't sound like the entire drive system is grinding itself away. It sounds like an old truck.
Shifting mine compared to the GU is as easy, but there's no flutter. You can actually feel the gears trying to slip into each other on the GU. On mine they just slip right in. There's no "Ka-Chunk" on mine...just "Clunk".
I'm nearing the total break-in period and if this is the way the rig runs on break-in, I couldn't ask for any better.
uh, You know, the turn signal cycling unit gizmo.
