MartyL wrote:BEAUTIFUL!!! Welcome!!!
P.S. If I may make a suggestion... Get yourself a dog collar to use as a tether for your sidecar windshield apron. If you leave it like in the pics with the apron pulling, the eyelets will eventually get weak and possibly rip. I got one at a pet mart. Works great......
If you reverse the grab bar, as I have done, which is very easy to do for even a klutz as myself, then the problem is essentially solved without much else necessary. I have a friend who has a Ural that someone added some long J-shaped bolts to, at the mounting bolt area for the hack windshield. It was a simple mod and looks pretty good. It adds support at the windshield and doesn't distract from the thing. Best thing is that there was no drilling required to bolt them into place. Here are some pics of the mod. I may do it myself, but just be aware that I am simply holding the j-bolt in place in these photos. His j-bolts were painted the color of the hack. These pictured are zinc plated 1/4"X6" ones that I have on hand for pics. They can be turned either direction when installed, but don't look as if they require drilling, and simply go in at the upper bracket mounting hole. (It may require a different size than what I used for the picutres, but these should give you the idea of how they work). They gave good support and were not in the way, either. Not sure if I'll follow through and bolt them up or not, but I wanted to show some pics so anyone could understand how they were done.
So far, I have never had any real problem with anyone actually using the grab bar to exit the hack. I expected it from all the posts I had seen in the past, but I have never had anyone do it so far. Lucky me!
Even when the grab bar was not reversed, I never had problems with passengers grabbing onto it and putting stress on the skirt or windshield frame.
(Update: I installed one of these j-bolts today. The more I look at it, the less I like it. It works, just as my friend's does, but I just don't like the looks on my Troyka. I'll pull it off tomorrow most likely. For someone else, it may be ok, but I just don't like it on the Troyka.)
A sidecar without a dog, is just another sidecar.
