antsaint wrote:BTW, here are some pics of what it's looking like around the gearbox plug and up around some of the housing. Anything look out of whack?
It's hard to tell from the pictures, but all in all it looks pretty clean under there. One area you really wanna check ist the "shelf" just under where the transmission mates to the motor, it sits above the top of the oil pan top. If the main seal is leaking, that'll be the place and that "shelf" will be covered in oil.
Other places I have found leaks on my 650 (my 750 aint leaking yet - knock on wood)
- Drain plug (either a crappy O-ring, buggered aluminum crush washer, teflon tape on the threads helps)
- Reverse lever seal (easy to fix)
- O-ring on clutch actauator cylinder (a little harder to fix)
- Valve covers (easy fix with a new gasket)
There's a reason they make more oil...
