Ural Key Blank
BobM
Ural Key Blank
Postby BobM » Fri Mar 05, 2010 11:06 pm
After trying everywhere to find a match for the original Ural key, I finally went to a full service locksmith. He cut a B1 key blank to match my original key. Then, because it was too thick and wouldn't go into the ignition, he filed both sides down to make it thinner. Works perfectly. $2.45 was a lot cheaper and quicker than the $10 that I saw one advertised for on Ebay for a blank. :D
BobM
Knoxville, TN
2013 Ural Tourist
2004 Suzuki Burgman 400
vt ural cycles
Re: Ural Key Blank
Postby vt ural cycles » Sat Mar 06, 2010 12:11 am
ILCO 1536r ----that blank has worked in the past.
TEST EVERYTHING 1ST,2ND,3RD,recomend it 4TH. YES IM A URAL DEALER !!! !
Z-Man
Re: Ural Key Blank
Postby Z-Man » Sat Mar 06, 2010 10:03 pm
I had good luck with the B1 as well, but you do need to put a little grind on the teeth and at the front to make it work.
'10 Ural Gear-Up (другая женщина the "Other Woman")
K&N Air Filter, Gossie Needles, 127.5/42 Jets, past 20K km and running strong. Someone stole my cats.
What broke and needed fixing: speedometer gear, hack stub shaft.
"Ride today, because you don't know what tomorrow brings"
Northwet
Ural Key Blank - trunk & gas cap?
Postby Northwet » Sat May 05, 2012 12:46 pm
I'm bad,
I lost a key fob with keys for the trunk and the gas cap on my 2011 Ural. Has anyone found key blanks that will work for these?
North"wet"
Fresno, CA
2011 Ural Patrol "Meanderer"
Born To Meander
