Tach install
berger
Tach install
Postby berger » Sun Jan 24, 2010 1:15 pm
I was wondering if someone has some detailed instructions on how to install a tach on an 07 with the Ducati ignition? I am electrically challenged.
Berger
2007 Ural Patrol (1st Owner)
Many, Many Mods.
ickie
Postby ickie » Sun Jan 24, 2010 3:11 pm
I installed my tach and have a Ducati ignition,
the instructions come with the tach are spot on.
there is 3 wires, positive, negitive and a green wire which goes to the positive side of your Ducati ignition coil, which I think was the green wire in Ducati ignition harness, which has 3 wires, lol.
the 2 big nuts on top of your fork are threaded inside except for the top, just drill out the cap and put a bolt in it to mount your tack on.
"Its Was A Full Time Job, Being A 2000 Ural Patrol Owner" 650 cc, Pekar K-68 Carbs, Ducati Ignition, Extra Capacity Oil Pan, 40 AMP- 2 Circuit Fuse Box With Relay In Side Car, New Tach, New Cruise Control/Throttle Lock, New Nippon Denso Alternator, Trailer Hitch, New 2-Driving Lights, Harley Police Seat, New Custom Made Nylon Cover, 5 New Sachs Shocks, New Duro Tires.
heindlengineeringural
Postby heindlengineeringural » Sun Jan 24, 2010 4:24 pm
Here are the instructions that we send with the tachs that we sell. The critical wire is the green wire on the tach that needs to go to the green wire on the Duc harness under the tank.
Heindl Engineering, LLC
4440 Quaker Trace Rd
Eaton, Oh 45320
(937) 787-3686
Tach Installation on Ural Models with Ducati Ignition System
There are four wires coming out of the tach: Red, Blue, Green, and Black. Their purpose is as follows:
· Black is the ground
· Red is a power feed to the tach
· Blue is a power feed to the backlight of the tach
· Green is the feed for the tach to read RPM
Wiring should be done as follows:
1) Attach the Red and Blue wires to a power source that is hot when the key is turned on.
2) Attach the black wire to a grounding point.
3) Attach the green wire to the green wire of the motorcycle wire harness. You will need to trace the wires up out of the timing cover through the plastic connector to find where the green wire of the motorcycle wire harness is located.
NOTE: It is very easy to attach the wires using a “quick splice” connector that pierces the existing wire harness. These can be obtained at any automotive store.
Ural Dealer in Southwest Ohio
(937) 787-3686
www.heindlengineering.com
sales@heindlengineering.com
berger
Postby berger » Sun Jan 24, 2010 5:46 pm
Ok thanks.
I wasn't sure if I had to get inside the ignition module. Now to determine which wire is hot....
Berger
Many, Many Mods.
russian iron 2000
GREEN WIRE
Postby russian iron 2000 » Sun Jan 24, 2010 6:27 pm
i have the russian ignition 2005 what color is the wire that i need to hook up my green from the tach to on the bike ?
Art
Gear UP 2005
Postby heindlengineeringural » Sun Jan 24, 2010 6:37 pm
You can hook up down at the coil inside the timing cover with the russian ignition.
(937) 787-3686
Users browsing this forum: No registered users and 10 guests
