2017 CT 2-1 conversion and extras
flcruiser2302
Postby flcruiser2302 » Fri Jun 16, 2017 5:54 pm
Here are some pics of what I did today. Basically added some water bottle mounts, a small rear fender rack from Amazon, $25, with a camo bag I had as a multi function carrier. I did mount the front rack too. Now to the 2-1 conversion. Once all the parts were received, went pretty smooth. I did end up using one of the cat less pipes I purchased before just to get the needed angle for the Indian Chief pipe to work. I know it looks pretty ugly for now, but there is still work to be done, taking it to my welding buddy tomorrow to weld the tip back on. I gutted the muffler and installed a V&H 12" baffle, bolted oit in and spread the inner portion to fit into the 4" pipe. I also added a smaller 3" long 1.5" round baffle to the tip just to quiet her down a tad more. I taped it with aluminum tape and road it around the block, it really has a nice 750 sound to it now. Not loud, just throaty. I cut off the indian mounts and will use something different than the ural mount as after its welded together, I am going to wrap the pipe with heat wrap and then ceramic coat that in black to finish off the blacked out look. When I pulled the O2 sensors out, I did notice they were sooty, telling me its a bit rich. That's the opposite effect I would have thought from running it with stock pipes with no cats and a K&N drop in filter, really thought and heard it would be a bit lean needing a fuel controller, hence me ordering the Dobeck EJK. I will see how this runs after a few miles as I cleaned the sensors and will check out tose next weekend. Either way, the dobeck is coming and I probably will install. I will keep things posted. Cheers and thanks for all the help and advice on this journey!
John in Orlando Fl
2017 CT
2-1 exhaust with cats removed, K&N drop in filter installed along with Dobeck EJK set at stock settings.
flcruiser2302
Re: 2017 CT 2-1 conversion and extras
Postby flcruiser2302 » Fri Jun 16, 2017 5:57 pm
more, I also added a power outlet in the tub. I love patches, used magnets hot glued to patches to attach to rear. Born and raised a SC Gamecock, so have a cutout from tag mounted as well.
John in Orlando Fl
2017 CT
flcruiser2302
Postby flcruiser2302 » Fri Jun 16, 2017 6:00 pm
Not a good look at the fender rack, but you can see it here. I will post a link. It works great! Can't beat it for the money!!
https://www.amazon.com/gp/product/B013G ... UTF8&psc=1
John in Orlando Fl
2017 CT
cateyetech
Postby cateyetech » Fri Jun 16, 2017 9:40 pm
WAY TO GO!!!
Looks like you a good time with your ride :D
Let us know in a few weeks if you really like the 2-1 or not :lol:
and don't let the milspec monkey know about the secret squirrel's mission :lol: :lol: :lol:
:cheers:
2003 Gear-Up
"If you have an Apple, I have an Apple and we exchange our apples, we each will have an Apple." "But if you have an idea, I have an idea and we exchange our ideas, we each will have two ideas."
fbeurne est motorcycle forum France
flcruiser2302
Postby flcruiser2302 » Mon Jun 19, 2017 7:44 am
Final product wrapped and installed.
John in Orlando Fl
2017 CT
Postby Tomcatfixer » Mon Jun 19, 2017 9:01 am
Would you kindly post some side profile images of your rear fender rack without the bag attached? I'd like to see how it looks unladen.
Also, if you click the "Place inline" button after you upload them, the images have a much "cleaner" appearance in your posts.
Virginia Beach, Virginia, USA
2015 Ural cT "Mobile Chernobyl", 1999 Ural Tourist "Desert DisGrace: the Iron (Oxide) Curtain", 1994 Honda VFR750F, 1986 Yamaha FZX700S Fazer
flcruiser2302
Postby flcruiser2302 » Mon Jun 19, 2017 1:00 pm
https://www.amazon.com/gp/product/B013G39YD6/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
This is the rack. I have the bag zip tied to the rack but will remove it to take some pics. I sort of got ahead of myself there. The rack is small but does what I want. I put a big rubber spacer under the back to level it out, you will see when I get home from work and post. Thanks for the tip on "inline" posting of pics, but do not know what it does. I will repost a pic to see!
John in Orlando Fl
2017 CT
flcruiser2302
Postby flcruiser2302 » Mon Jun 19, 2017 1:01 pm
unless its just my computer, that looks exactly the same as the one posted without using the "place inline" button....
John in Orlando Fl
2017 CT
Postby Tomcatfixer » Mon Jun 19, 2017 1:08 pm
Must be your computer, because there is no white box with a dashed border around the image on the one you placed inline.
Lookin' forward to the rack image.
flcruiser2302
Postby flcruiser2302 » Mon Jun 19, 2017 7:30 pm
here ya go.
John in Orlando Fl
2017 CT
flcruiser2302
Postby flcruiser2302 » Mon Jun 19, 2017 7:31 pm
sorry, sideways, gotta lean your head>
John in Orlando Fl
2017 CT
flcruiser2302
Postby flcruiser2302 » Wed Jun 21, 2017 5:44 am
Whoever helped out and fixed this, thanks!
John in Orlando Fl
2017 CT
Postby jaybird » Wed Jun 21, 2017 7:44 am
Photos are still sideways and without expanded view on my MacBook Pro, if anybody cares.
flcruiser2302
Postby flcruiser2302 » Wed Jun 21, 2017 9:13 am
Wow, now sideways again! I looked this morning and they were straight. Anyway, you get the gist of what the rack looks like installed on the fender. No, it will not support a passenger, but it does what I need it to do, carry a bag with accessories in it, phone, extra gloves, binoc's, etc.
John in Orlando Fl
2017 CT
autoloclys
Postby autoloclys » Fri Jun 23, 2017 2:45 pm
I think this is the rack you used on the front of the tub, yes?
https://www.amazon.com/Premium-Tour-Pak ... ggage+rack
Boston MA
2012 Retro M70
1979 Yamaha SR500
Return to “Modifications & Accessories”
Users browsing this forum: No registered users and 5 guests
cron
